Hot side intercooler pipe
I am looking for an aftermarket hot side pipe that does not leak. I hooked up my air compressor to where my air filter is and found a significant leak at the turbo connection of the factory hot side pipe. Is it normal for a leak or should it be air tight? Any recommendations for a quality piece that doesn't leak. I saw the Rudy's for $119 which seems cheap. I do like the AFE one which matches my intake. Is there one that uses a hump hose at the turbo side or can i just run a hump hose over the joint with a clamp before and after.
Kxc
South Jersey
AFE looks like a solid choice but I wonder how fitment is with a 3" pipe the entire way. Being that the factory turbo has the stupid quick connect I don't think it will accept a hose with a clamp.
ImAti0n
absolute performance has a hot Side pipe
Sent from your mom's house using Tapathatass
