That is normal. It is advised to hook up to a scanner to diagnose your no start problem. There are a few things you can do without it though. Check engine oil level, because it wont start if it gets low enough. Unplug the icp sensor and try to start, also, if you find oil in the connector, the sensor and the pigtail need to be replaced. You can also check all fuses.
What scanner are you using? These trucks are particular on what can be used on them.
