How much boost on 6.4?
7.3powerstroke00
Brownwood
How much boost can you run on stock gaskets and bolts before you need to invest in studs?
The only mods I have are....
H&S hot damn 300 tune
Afe stage II intake
5 inch dp back exhaust
Valair dual disc clutch
After installed intake today I test drove and at 65 in OD roll into trottle and it will spike above 40psi on factory gauge....
Dzchey21
wyoming
Hp is the better regulating factor.
500 would be "safe" anything over that is asking for problems
Sent from my DROID BIONIC using Tapatalk 2
7.3powerstroke00
Brownwood
Thanks for the info..... I guess I better get some studs soon..... According to H&S I'm suppose to be in the 550-565 hp range....
91turbogsx
Gardner MA
I push 50+lbs quite often in my work truck. 150k miles with 50k of that tuned. Pukes a little bit on a hard pull. Just waiting for it to finally give up. LOL
And my roommate put down 580 hp on stock studs and it's still goin strong.
powerstrokin15
Charleston, WV
i saw around 50psi often on my stuck studs and never puked. youll be fine with just the 300.. it wont last forever.. but youll be ok. no need to worry imo
08BIGRIG
WI
I have over 600 with factory studs and gaskets. I also see 52 PSI on a hard pull. So far I have not had a problem. It has been about 5k miles on it like this, but I know that my time is coming sooner or later.LOL
SEABEE08FX4
Montgomery TX
I'm still on stock bolts and gaskets, under WOT I have hit 60-65 psi with my S366 with no issues. I wouldn't recommend it but it can be done.
MINK
London,OH
I would assume your backpressure is also lower than say stock chargers being pushed up there.
Erikclaw
Central CA
I ran Spartan's 310 for quite a while, at the end it would puke just feeling the keys in the ignition. HG's shot, heads cracked.
