How much PSI?
dietoremain
Norco, Ca
Just curious how much PSI ya'll run in your tires.
My Bridgestone Dueller AT's are 80psi max, I run 70 in em all day long..
My MPG's seemed a lil down, so between the cold weather and my tires all being below normal psi...and found one has a slow leak(we plugged it but its got a lil leak, took a month to leak down 20lbs). Oh well i'll get my $ out of them they have been great tires... no complaints.
907DAVE
AK
I will adjust per tire wear, but the CC usually around 55 - and the dually about 60.
tbsimmons
Bakersfield, CA
Use a chalk line on the tire and drive for about a block without turning the fronts.
Set the PSI to what the line tells you.
