How to: Clean EBPS to gain lost MPGs (Video)
Big Bore
9000ft in the CO Rockies
Next show how to prevent ebpv problems and show the ebpv, ebpv tube, ebpv sensor and ebpv pedestal in a trash can and a plug in the manifold like mine. LOL
RedSmokey
Sacramento, CA
Doesn't the truck use the sensor reading as a parameter for tuning? But I am with you on dumping the ebpv
CGMKCM
Randolph County, NC
Nice job on the how to video! The camera operator is also doing a great job getting the camera in position.
One suggestion on the EBPS cleaning is
1. remove the sensor, try blowing compressed air through the tubing. If the air went through the tubing, clean and re-install sensor. Your tubing is not clogged.
You could spray solvent like brake cleaner and blow more air through the tubing. I guess you could also run the speedometer cable through the tubing without removing it from the engine?
moose99psd
sunny central oregon
i believe a while ago someone was using grease to clean it out, pull the sensor and with adapters add a grease fitting to where the sensor goes and pump it till it goes through, it will melt with heat and burn off.
Big Bore
When that grease burns off won't the residue be forced up into the sensor and put you back at square one, and possibly needing to replace the sensor? Just seems like a poorly thought out method.
PatriotHauling
Ventura, CA
I want to say thanks for the support guys! I checked my online stats today, and I have gotten a HUGE response to this video.
Thanks guys, I love getting feedback from you guys!!
