There is a data tag in the driver's door opening. There is a code for AXLE that will tell the ratio that it was built with.
You can also jack up the rear wheels, put the trans in N and rotate the tires one revolution. Have a helper rotate the other side while you do one side. Count the driveshaft rotations and you'll know the ratio.
