How to turn your EBPV into an exhaust brake
TrailerHauler
Michigan
I put a switch in my old white dually to use the EBPV as an exhaust brake and it worked exceptionally well, and the cost to do it just makes it all that much better.
bengalboy9
It won't let me download those directions I tried doing it and nothing I rhx I have something g messed up anyone with advice
oldschool
casper Wy
the only problem I see is the possibility of starving the turbo for oil when the bpv is activated. Talked to beans about this when I put on the D66 from them, and he said that they had some problems from truck in montana burning out the turbo bearings. They quite using the bpv as an exhaust brake, and the problems went away. He wouldn't go so far to say that using the bpv was the problem, butttt. I was thinking of finding an actuator cylinder and modify it to work. Might save a few bucks.
