Howes anti gel
hunter scar
Anybody ever had their truck gell with howes additive? it was -3 here last night, My 2002 started real good drove about 2 miles it started trying to gell up. I mixed 12oz in it like the bottle said
cleatus12r
Reed Point, MT
The ONLY "additive" that works as an anti-gel is a 30-50% mix of good ol' #1. Add stuff for lubricity, not to keep wax from forming in #2.
Before anyone says, "What about Power Service 911?" It's NOT an additive. It is not intended to be added to the tank and run regularly. It does what it's supposed to do ONLY when needed.
rode0_man
North Dakota
Ive had friends with the same problem as you, therefore, I never use Howes. It turns to syrup in the bottle when it gets cold and that's enough for me to stay away from it. 911 is for thinning fuel that has already gelled and it works, ive used it plenty. But you still have to treat the fuel that you add 911 to because it doesn't prevent gelling it only reverses it for a period of time, I learned that lesson the hard way. Power Service in the White bottle or Stanadyne's anti-gel formula both work well to prevent gelling. Those are all products that I have used and they worked for me. I hate to, and hardly ever, use #1 fuel. I just pour some extra additive in if I know its gunna be really cold for a couple days and never have any problems, but I do keep a bottle of 911 with just in case.
ToMang07
Mainah!
When it's REALLY cold I use 2x what it calls for, but I use Power Service (White bottle) and have never had an issue. Was -28*F (Before wind chill) and I still started the truck that morning no issue.
psduser1
on the road
I've run standyne down to -20 with no issues, currently running ps. No problems down to -5 or so. Trying to stay away from the water emulsifiers, as the prefilled doesn't like them.
tgf
southwest mo
I've never had an issue, but I use more than the bottle says and keep over a half tank when it gets that cold.
