hpo line removal
snealjohn
Any secrets to getting the hpo lines off the quick connect fittings. Have the tool and some come off like they are supposed to but 2 will not. Considering cutting the lines and removing with a wrench.
Replaced the hoop, outlet fittings and new hoses. Failed to replace the inlet fittings on the heads, biggest mistake ever. Leaks on driver's side and can't get the fitting to release for replacement.
Has anyone used the oil pressure to blow the connection after pushing the sleeve down into the fitting?
psduser1
on the road
Get the wrench in and keep working the line. It'll come loose.
I wouldn't recommend using oil pressure, lol.
whs^^^.... get your wiggle on! gotta work it and wiggle it. twist, push, pull.. i guess i haven't ever seen them be stuck on.. will the line spin around freely without the tool in it?
