hpop leak help
ryanss22
upstate central ny
I finally got around to being able to start my truck with all the new goodies (see sig) and I started to see oil in the valley, so I figured just a bad gasket. I ordered all new gaskets from riff raff and installed them last night along with my gen 3.. today I go start the truck to let it run and get the air out and theres a leak again!!! got the mirror out and a good light and its leaking from back of the stock hpop where the big snap ring is right at the bottom, I can watch it drip out at a good steady flow..
How do I fix this problem? is there something inside that can be leaking?
also with the gen 3 my truck is now throwing a cel after the high idle tune is put on. according to my maximizer scanner its "inj pressure higher or lower then desiered" and "no inj press at crank" but it still fires up. after a bit of cranking.
my scanner is showing right about 8-10%dc and 800-900 pressure at normal idle but when the cel is thrown it jumps up to 27-30% with same pressure. pulse width is .8-.9 I belive (those are the #'s I remember seeing of the top of my head)
I did save all my info so I can go back and recheck it.
any idea or help
ryanss22
upstate central ny
heres a pic for reference
ryanss22
upstate central ny
ok thanks david, Will I need to order a hpop new mounting gasket or can I reuse it? I was told its a crush gasket there for one and done kinda deal..
ryanss22
upstate central ny
Any one have an idea on the cel issue? Also my oil pressure dash gauge shows zero untill eengine is reved up. Then goes up to normal and falls back to zero at idle
Andrew
Kent, WA
The steel gasket hpop to cover is reuseable. And the icp high or lower than desired is prolly due to air in the system.
ryanss22
upstate central ny
Ok thanks guys. I ordeed a new kring and gasket. Shoukd be here today. Kinda what im hoping the icp issue is just air. Have had the hpop apart so many times chacing leaks. Ill put everythibg togeather tonif ht and let it idle n drive it to get air out of system. Then go from there
