Cratos
Ok I have a good one for you
I had the front cover replaced on my 97 .now the HPOP res leaks down and causes hard start. Never did this before.
I checked the res and it is empty if it sits a couple days so I have to crank it to get it filled so it will start.
I pulled the res to see if the O-ring was messed up, and found that it has a 99+ cover on it with the machined cut out for the filter screen. I refilled the cavity that feeds the HPOP and it is leaking down slowly I had already pulled the lines from the heads to see if it was injector O-rings and with the lines propped up above the res it was still leaking. So were can the oil be going???
