HPOP
Lee
West Jordan Utah
Any body know the minimum ICP Pressure to start?
Also if you unplug the ICP Coil do you get no pressure or full pressure?
Thanks
Lee
neverkickn
AR
Thanks
Lee
Do you mean the ipr coil? If so, then you will not build pressure with it unplugged. If you mean the icp sensor, then the truck will run off of preset parameters stored in the pcm.
ToMang07
Mainah!
Thanks
Lee
If you unplug the sensor, the computer essentially "guesses" the pressure, generally causing a rougher idle. You will get a CEL, but having the ICP unplugged should not stop the truck from running.
ToMang07
Mainah!
Lee
West Jordan Utah
Ha found my problem........... the samped metal nut holding the IPR coil came off.
Nut and coil found in bottom of valley.
It's all good now.
Thanks every one.
Lee
