ht3b
vanderchevy18
Benton, Ks.
T6 housing non wastegated. It has absolutely no in and out shaft play and a barely noticeable side to side. Its a journal bearing so its to be expected. 76mm inducer and 107mm exducer on the compressor wheel and an 81mm turbine wheel. The compressor wheel is a little worn and needs replaced. $400 as is and $500 with a new compressor wheel.
Text 316.650.1063
