AirFishAutomotive
Im changing the set up on one of my trucks and going s different direction therefore Im putting my htt big bad wolf turbo up for sale.
specs Ported shroud compressor housing for flow increases exceeding 30%. The 88mm compressor wheel provides similar flow to the Garrett ball-bearing turbo. *1.00 T. Hsg. instead of the stock .84. (For lower drive pressures and extended top-end horsepower.) *The baseline actuator setting is 20 lbs. and is fully adjustable. *360 degree thrust bearing and a shaft shank diameter of 5/16" in diameter instead of original 1/4". This gives you the strength and durability you need.
this is a direct bolt on for 99-03 they go from around 1400-1600 new with 150 core charge. Also not the most important thing but these turbos do have a good amount of whistle!
I want to get 800 OBO for the turbo shipped. If I can not get close to that I will just keep it.
I do not have the factory intake hose for it but i do have an intake hose i can include that i used on it (silicone 4 inch hose)
hardly any shaft play up & down (normal movement nothing to be concerned about) and 0 in & out
here is a link http://www.dpppower.com/73-turbos.html
this is a good turbo for someone that doesnt want to spend the money of buying brand new and get a good jump in power for a good price.
Also unlike a gt38r these turbos are rebuildable!!
pay pal verified
prefer pm
pay pal verified
prefer pm
