AirFishAutomotive
I may be buying another truck so I will not be building my truck as planned. therefore Im putting my htt big bad wolf turbo.
specs
Ported shroud compressor housing for flow increases exceeding 30%. The 88mm compressor wheel provides similar flow to the Garrett ball-bearing turbo.
*1.00 T. Hsg. instead of the stock .84. (For lower drive pressures and extended top-end horsepower.)
*The baseline actuator setting is 20 lbs. and is fully adjustable.
*360 degree thrust bearing and a shaft shank diameter of 5/16" in diameter instead of original 1/4". This gives you the strength and durability you need.
this is a direct bolt on for 99-03
they go from around 1400-1600 new with 150 core charge.
I want to get 800 OBO for the turbo shipped. If I can not get close to that I will just keep it.
I do not have the intake hose for it
hardly any shaft play @ all
here is a link
http://www.dpppower.com/73-turbos.html
this is a good turbo for someone that doesnt want to spend the money of buying brand new and get a good jump in power for a good price.
pay pal verified
prefer pm
specs
here is a link
pay pal verified
prefer pm
