Hub Replacement / Upgrade
Lugger007
Ct
My hubs on my 2012 f250 have not been wanting to fully lock lately. Need to move the truck before hub will fully engage. Thinking after 117k miles might be ready to replace them.
What brand do you guys recommend? OEM or aftermarket? I've heard good about warn but looking for opinions/advise from guys who have done this before. thanks
Nj67
South NJ
Mine went bad at 12 or 13k and just had oem put back in under warranty. Will be putting warn hubs in when they go
Zmann
there is only one aftermarket choice and it's manual
made by Warn warn also makes your OEM hub and unless your breaking hubs I don't se a reason to swap since your OEM's can be treated as a manual hub anyway
if your failing to lock I would check the vacuum system because a low signal can cause a partial /no lock issue
