hub won't go back in
6
6.4stroke
Guest
I took my hub off because it was pretty tight to turn. Now I can't get it back in i get it lined up it goes almost all the way in but then stops was wondering if anyone had advice thanks
Zmann
Hmmm
did u lube it up ?
can't think of a real problem area but if you get in a bind you can pull the otherside to compare and see if it will go on
you can also tape up the end or make a cover of some sort and still drive it if you really get stuck and need to drice
greasltn
Hillsborough, NC
The splines need to be lined up. Manually lock the hub and when it gets to the point where it stops, turn the wheel and the axle will line up and go in.
Tree Trimmer
there is a little alignment pin on the back side of the lock out that needs to go in a hole.
if you get that close, then reach behind the tire, and grab the u-joint and wiggle it, so it moves the axle shaft, and it will slide the rest of the way in.
your fighting the axle shaft not being "in line enough" to let the lock out slide the rest of the way in, or that little alignment pin not going in a hole.
Zmann
Never noticed a pin ?
see pdf next post
  • auto hubs.pdf
Zmann
opps wrong link above
  • PVH 2006 warn.pdf
6
6.4stroke
Guest
New hubs are in. Jacked up the drivers side so I could turn the tire. Driver and passenger hub slid right in. Thanks guys for the info!!!!!
