hybrid turbo
rat49f6
Vernon,NJ
i just got an obs and i hate every p[art of the turbo mounting
are the e99 and obs center sections the same???
could i bolt the obs intake and exhaust housings to the e99 center section?
im pretty sure e99 and obs pedestals are the same height, am i right??
superduty4x4
Newport, WA
I've been wanting to do this very thing for a while now but haven't had the time to try and find an E99 turbo and really look at it. You'll probably end up eliminating the EBPV since they hook up differently on the OBS and E99 but you'd probably do that anyway. All the 7.3 turbos, even the late model, use the same center section from what I'm told.
rat49f6
Vernon,NJ
Ill keep everyone updated if I try this
I have a half fubar'd e99 turbo and a e99 pedestal
Sent from my T-Mobile G2 using Tapatalk
Strokersace
Towanda, KS
The center sections are different. That's why the OBS turbo is BS to remove.
The heights of both the OBS and e99 are the same. You might be able to put an OBS exhaust housing on an e99 center and use the e99 pedestal for easier removal.
MossBack
UTAH
What is so better about the SD? I have been able to pull my Turbo in 40 minutes. Had to pull it couple times when I did my efuel. I have thought about this swap as the 66mm wheel can be purchased for about 100 and whatever the cost for machine
Sent from my PC36100 using Tapatalk 2
