Hybrid
Redneck6.0L
got big ones in the race truck and industrial 300cc in the tow truck, depend on what your trying todo with the truck
stroker57
frostburg,MD
i was thinking about going with 300cc myself trying to do 700rwhp on fuel turbo probably going with mpds kit with the 66 what do you think?
faster6.0
New warrens run very smooth and have seen 0 dilution thus far
07_powerstroke
Upstate, NY
Build a set of compounds that what I plan to do someday. Shawn with 300cc hybrids what turbos would you use for a street driven truck that spooled like stock? Would 800hp be realistic as a DD?
kyle43335
my biggest issue with hybrids,is what the technical error it places on the icp ratio. being that its 7:1.
meaning the intensifier piston is 7 times larger than the amplifier piston.
once you increase the diameter of the amp piston,to create a hybrid,its no longer 7:1. the only way you could retain the correct ratio,is to increase the intensifier piston diameter the same amount.
ive looked at this several times,and dont see enough room to do it.
Redneck6.0L
I realize the ratio isn't there but they flat out do make more power. So I'm not sure what your stressing about.
stroker57
frostburg,MD
i have warrens injectors now jj i called him friday about a set of hybrids he said it will be about a month till i can get a set because of stuff being back order
Pizza pig
MD
its an apples to orange comparison though, ill agree on a stock pump they will hands down.
add a second pump and throw in big conventionals :evil
Pizza pig
MD
I want to make mine into hybrids, only because this whole plugged spill port makes trucks idle like crap. Plugged ports allow you to use less icp to move a certain amount of fuel than a non plugged body. I'd like to move more fuel than 205cc without needing a second pump lol.
hybrids and adding a 480? hmmm
