Hydrolock- should I be concerned
superduty4x4
Newport, WA
Long story short I put new injectors in last weekend, and the cylinders didn't get purged even though I tried to clear them and the motor hydrolocked on me. Hit the key and it only turned a little bit before it locked up, did it once more, then I was able to get it to roll over by bumping the key. Truck seems to be fine, power seems good and all that happy horse chit, so how worried should I be? Anything I can do to check things over short of pulling the pan to look for U shaped rods?
Clem1226
if your REALLY worried you could do a compression test but if it was me......drive it and forget it.
SkySki Jason
N. GA Mountains
Most likely no damage done. The oil just was pushed past the rings. Its a good idea to spin engine over by hand a couple revs before using starter after installing injectors.
superduty4x4
Newport, WA
I did both actually. However, I did it with both the injectors AND glow plugs removed from the head, which is probably why I didn't get everything out. I know most guys put the injectors in then clear the cylinders, but I got advice from someone that I thought was sound saying I could do it with both removed. Well... lesson learned.
Chvyrkr
I usually use a cattle syringe and a piece of tubing to clear the cylinders after I pull injectors, before I install new injectors.
Hasn't failed me yet.
SkySki Jason
N. GA Mountains
Thats what I do, but I use a piece of brake line tubing that fits tightly into my Mighty Vac hose, but fits thru the hole. Before stabbing new injectors, slurp out the oil/fuel thru injector hole, then after injectors are in and before GP's - spin engine over by hand.
Chvyrkr
I haven't even pulled glow plugs the last few times, cranks normally.
moose99psd
sunny central oregon
Pull last two injectors on each side, wait till gluggin stops, pull injectors, install new injectors, pull gps, place valve covers on with one bolt, turn motor over with starter solenoid, reinstall gps and fire it up. I do oil changes with injetor installs allways so no need to worry about fuel in oil. Hasn't failed yet.
Chvyrkr
Imo suckin out the cylinders is overkill.
Could be, IMO it's more time efficient than pullin glow plugs and cleaner than blowing the fluid out against partially installed VC's.
Although possibly harder on the starter as your first hit against the starter that primes the rails is a full compression crank over.
superduty4x4
Newport, WA
The problem was I wasn't at home, so I didn't have my Mityvac or my "special glow plug removal tool" with me. I called a friend and he gave me the advice above, which sounded good at the time since I didn't want to have to fight getting the glow plugs started with the injectors in.
Oh well, it's running fine even though the tunes are too smoky for my taste. Sure scoots down the road good now!
CSIPSD
Bend, OR
You didnt call me... And I didnt tell you that... LOL
Otherwise it will be fine.
