I want to add heated mirrors to my truck
ecseymour
Williston North Dakota
Hi guys this is my first time to the website I have a few questions
I have a 2008 F250 lariat I live in Williston North Dakota it would be nice to have heated mirrors my climate control doesn't show the option for it if I purchase a climate control unit that supports heated mirrors and put on heated mirrors Will it work is it that easy just plug-and-play also I'm thinking about heated seats is it the same way to Took out my climate control it looks identical to climate control with heated seats and heated mirrors all the same wires so I'm just wondering thanks
Stroked777
Casper, Wyoming
I believe that will work but you might have to have the trucks ECM reflashed to allow for the climate control unit to work and for the heated mirrors to work, every truck comes from the factory with the same wire harness. So it makes it easier to add in different options that different trim pack trucks came with
co04cobra
WV
If its a lariat you should of had heated mirrors. I don't think you could delete that option.
The electronic temp control is not plug and play the whole dash harness is different from what I have found.
The heated seats and heated mirrors should be plug and play.
