Icon 4" lift 99-04
Krazykmainor
Mont Belvieu, TX
Is anyone currently running an Icon 4" lift kit on their 99-04 SD? I'm curious as to whether the front springs would ride better due to the progressive rate springs. They have 12 leafs to each spring pack, whereas a typical front leaf pack has somewhere around 4-5 leafs. I'm thinking this would help soften the ride quite a bit
cw96stroker
Central, Texas
I am running the Icon 4in lift on my Platinum, it ride much smoother than the rough country leveling kit and stock springs did.
Krazykmainor
Mont Belvieu, TX
Thanks for the input CW. I am currently running the rough country 2.5" leveling springs and the ride is okay, but not that great. I would like to go up to 4" but don't want the truck to ride like a tank. So that helps alot
Anyone else had experience with this lift?
Betarocker
Sea to Sky, BC
I run the 4" leafs, but I have mine mounted to 3" hangers/shackles. I have been running them for so long I don't remember what stock or add-a-leaf was like, but when I switched over I was impressed with the improvement. Proper shocks will also determine the ride quality. Don't expect a ride similar to a luxury sedan, they will still be truck like.
Krazykmainor
Mont Belvieu, TX
Yeah I know it's not ever going to be luxury, especially with the leaf sprung front end. But if I am going to move up to a 4" and the icon makes a difference in ride quality I would rather pay the extra money to gain that little bit extra.
I just put Bilstien 5100 series shocks all the way around and that made a world of difference
chappy
Marshall Mi
I can tell you that I'm not real impressed with my 6in icon springs. I went from 4in procomps to these 6in icns and the ride got noticeablely rougher. I am curious also if the 4in icons would be a noticeable differance over the 4in procomps I had which I thought rode great. I've thought a lot of gong to a 4in spring and 2in hanger for a better ride.
Homesteader
I was looking into Icon's 4 inch also but wasnt sure if 35's on 20x12's would clear,turning radius
Betarocker
Sea to Sky, BC
I haven't been in a truck with 6" Icon springs, but all reports say they are firmer than the 4". As the height goes up, so does the firmness.
chappy
Marshall Mi
They will clear but will rub. I had to trim my front bottom bumper metal part and I have dented up both bottoms of my fenders with the 6in.
Krazykmainor
Mont Belvieu, TX
I havent been in one either, but it only makes sense to me that the higher you go the worse it gets. Well in the leaf spring world anyway. But I could be wrong...who knows.
OBSWIZ
Wellington NV
FYI..35" will clear 35" on a 99-04 if it has V code fronts..
Stock V codes with a hanger kit will ride better than any aftermarket lift spring.
True the more arch a lift spring has+ lift the stiffer it will ride
Krazykmainor
Mont Belvieu, TX
Thanks for the info. I am currently running 35" with my leveling kit. Just feel like they look stuffed in there. I think its the appearance of the 4" and 35" tire combination that I like.
OBSWIZ
Wellington NV
If you like the ride quality of your springs we have 2" and 3" hanger kits, or if you still have the stock V codes a 4.5" hanger kit..PM me if I can help
