ICP voltage gauge?
HobbyStock62
Mpls, MN
I have isspro ev2s and am looking to monitor ICP before I make my injector choice. I can't seem to find a 0-5 volt ev2 guage. What are you people doing to monitor ICP?
HOOV3R
Central PA
Isspro makes an actual hpop gauge, that splices into the icp sensor, which will read icp psi correctly.
acf6
Manchester, CT
Scangauge 2. also use it for IPR %, voltage, ficm voltage, coolant and oil temp. lots of stuff actually
HobbyStock62
Mpls, MN
I have an interceptor scan guage, it does not have ICP voltage. Different scan guage or something? But that isspro ev2 0-4000psi will read accurately because it is reading directly from the sensor?
HOOV3R
Central PA
Correct. It reads from the direct from the sensor, not through the computer like the others.
Josh@DirtyDiesels
PA
the isspro gauge will work or you can use an edge cts. sct livewire ts should support icp voltage soon too from what I hear.
HobbyStock62
Mpls, MN
another quick question. so 4.8v=4000psi, correct? basically if it drops pressure at all with stock fuel, then i will figure out a high output set up before i get more fuel. but what does it go down per 10th of a volt? and what would be considered reasonable? 4.5v?
strokin6L
Springville NY
Even if it spliced directly into the ICP...the tune can give a false voltage/psi reading on some trucks. My truck is one of them with Eric's tunes. My hpop gauge is tapped right into my ICP gauge....only saw 1500psi and 2.3v when tuned. Turn back to stock and I saw over 3600psi and over 4.5v.
Pizza pig
MD
ICP voltage
(PSI) (MPA) Voltage
0 0 .02v
200 1.5 .4v
400 3 0.73v
600 4 .96v
800 5.5 1.2v
1000 7 1.4v
1200 8 1.6v
1400 9.7 1.9v
1600 11 2.1v
1800 12.4 2.3v
2000 13.8 2.6v
2200 15.2 2.8v
2400 16.5 3v
2600 18 3.3v
2800 19.3 3.5v
3000 20.6 3.8v
3200 22 4v
3400 23.4 4.2
3600 24.8 4.3
3800 26.2 4.5
4000 27.5. 4.7v
4200 29.3 4.9v
Hellen Keller sent this?
Josh@DirtyDiesels
PA
MorganY
college station, tx
Chris. I think we've had this discussion before. Putting the truck back to stock in your case pulled fuel back, giving you the higher pressure reading.
The isspro reads output voltage from the icp sensor. PCM cannot skew the that.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
HobbyStock62
Mpls, MN
So how can you get a correct reading? How is the scan guage or the other one reading it? It seems to me that if it can be scewed right from the sensor it can be scewed from anywhere. If I plug in the snap on scan tool will it give me an accurate volt/psi reading?
