Peroni
This has happened occasionally over the past 2yrs but is becoming more frequent. My idiot oil pressure gauge will start going nuts flicking back and forth. I put a real gauge on the hpo reservoir and got anywhere between 25psi hot idle to 50psi at 2200rpm so no problems with oil supply. I replaced the sensor and cleaned the connector, it's still happening. It does this randomly but so far have only noticed it when the engine was hot. Its happened anywhere from slowly pulling away from a stop sign to passing traffic at 70mph. Electrical interference of some sorts? :shrug: I could hold the throttle steady and watch the gauge go crazy but give it a tad more or less and the gauge goes right back to normal. It's the weirdest thing!
