Idle great cuts off with load
Nasty7.3
Eastern VA
The Truck is a 2008 6.4 with a egr delete dpf delete and a sparton. The truck idles fine but as soon as you start to drive it the truck cuts off and the rail pressure drops to nothing basically. Any Ideas?
greasltn
Hillsborough, NC
Check your codes. Also check the base fuel pressure. If the low pressure pump is not working it will starve the HPFP and drop rail pressure.
Nasty7.3
Eastern VA
Low pressure is around 5 pounds at idle I haven't checked it with a load yet. I will tell you all the codes tomorrow.
greasltn
Hillsborough, NC
Low pressure system specs are 3-7 psi. at idle, so you're in spec. If your filters are clogged you can get pressure at idle, but it will drop off with any kind of load.
Nasty7.3
Eastern VA
Codes are p008c fuel cooler pump control circuit/open
P040d Egr
P2291 injector control pressure too low- engine cranking
