Info on pacer wheel
BFT
southern cali
Im rying to match the other wheel that got damaged on my truck. From what I've found it's a pacer wheel that was found on 03-06 super duties.
I ordered one but the bolt pattern was messed up somehow but the holes drilled (not the stud holes) looked smaller, most likely because it was a 8x160 vs what I ordered 8x170
Question is, does anyone have more info on the wheels?
Thanks
BFT
southern cali
This is the picture of the wheel
fordfreak4life
Pacer 164p you will have to get the measurements off of one of ur current wheels and talk to a wheel supplier.... I have a good wheel n tire guy if u have any other questions
Sent from my Milestone X2 using Tapatalk 2
BFT
southern cali
What measurements will I need?
I gave them this info
17X9 PACER ALLOY 164P LT MOD POLISHED 8X170 F250 F350 SUPERDUTY FORD
PTSUPERD
Roberto...that wheel is identicle looking to a Mickey Thompson classic II. If you come up short, might go that direction. Who knows..could be the same wheel.
BFT
southern cali
Backspace and offset
How can I go figuring that out?
That's what I asked when I first saw them. The wheel itself sticks out farther then factory. I have 35" Toyo M/T's mounted already. They had to find a 8x170 17" wheel.
fordfreak4life
How many various offsets do they have for a 17x9 with a 8 on 170 lug pattern?
Couldn't tell u for sure.... There are guides on the Internet that tell you how to measure them.... All u need is a yard stick and a tape measure
fordfreak4life
I can do that. Cool deal, I'll head over to the tire shop after work
Good luck homie, they should be able to put it on a spin balancer n get all that info
BFT
southern cali
Turns out the wheel is from American eagle wheel company. Hopefully they still have the wheel available
