White_monster
Like the title states. What info should we be aquiring to setup our trucks. Also if some of this data has been collected please put it up and list the setup specs so others can understand it all and make use of it. I'll list what I think should be collected and feel free to add more. Thanks.
Turbo inlet pressure - obviously this will be vacuum
Turbo outlet pressure - after each turbo
Intake air temp
Turbo wheel speed
Back pressure - between turbos if compound setups being used
EGT's - be great to get each cylinder but it's unlikely someone will go that far
Vgt duty cycle - if used
Let's also try to discuss how collecting this data will help the setups, things like the Vgt duty cycle haven't been brought up much. I talked with Mike Haller about the Vgt settings and how it needs to be tweaked. Anyways let's see what we can come up with.
Intake air temp
Turbo wheel speed
