I just put a new set of cups in and 2 of them started leaking at about 1000 miles. I was told by a local shop to use red loctite to seal them but i was wonduring if there is something better to use to seal them before i try this again?
What is causing your cups to fail in the first place? If you know? Was it overheated? Or just a lot of miles? Or high injection pressures?
This may sound stupid but did you reinstall the injectors with all new o-rings?
