Injector spray angle
golfer
none of the holes share the same angle (as the injector sits ~ 11deg off perpendicular, nor is the injector in the center of the cylinder bore).
V-Ref
9 miles high @ 550 mph
I wonder what the maximum of timing BTDC given a factory piston bowl dimension before you begin the SOI and it "sprays" out side the bowl on the piston? Hmmmm. ..man if a guy could figure that out
ja_cain
My brother has software that can model this. If only I could find/create a cad drawing of the motor or just one cylinder.
TARM
My bet is that has already been figured out. First of course by Ford tech but after that I have a hard time believing with all the $$$ has been spent someone has not already done this. Hell, while maybe not to the exact Nth degree, I would think you could establish this with hard parts and then firing a injector, otherwise certainly with software. I would be welling to wager the likes of Golfer and HotRodTractor know those figures
powerstrokenstang
Verona VA
Didn know it sits off, interesting. But what about the nozzles themselves?
I know about where matts soi btdc timing can be to hit a stock bowl is but who knows how that goes with diff tuners. I dont have anywhere near stock bowls or pistons for that matter.
CurtisF
At what injection pressure and RPM? That's where it gets fun. :poke:
