Trying to start engine for first time, new IPR, CPS, and honey badger jr. Engine is outside of truck, everything should be hooked up. Got some pressure in oil rails. No oil coming from inj oil spouts. Any advice?
I think I'm only doing 500 psi oil injection pressure. Air?
500 PSI is enough to fire the injectors.
The what to start light doesn't go out.
earlier you asked if power needed to be at starter relay, that where the glowplugs get power
