Installing a trans gauge
aaron.luckert
I've herd two different ways. Not sure if one is true or not. People told that I would have to drill a hole in the case and tap it. Then I herd just put it in the test hole. Which one is true ?
if you drill a hole anywhere, do it in the pan, not the case.
you could also put it in the test port if you wish
webb06
Seneca, MO
Why not just use a digital readout such as a dashdaq, H&S, edge or anything of the like to monitor temps. Rather than installing an analog gauge and having to find a port
aaron.luckert
Yea I some what new to the diesel performance. Trying to learn the right ways to do things. Thanks for the replies.
