Interco SS M16 295/75R16
NCPowerStroke
first off im sorry about so many tire and rim threads... this is my last one for a long time i promise.
ok i need new tires, and i really like the looks of the SS M16s. will i be able to fit 295/75R16 tires on my stock 04 F250? the tires will be put on the stock lariat wheels (will that cause a really big problem, or will they be ok on stock rims?).
thanks for the help
03 tx pwr stroke
Texas
Should be fine. I'm leveled and have PLENTY of room. Plan on going quite a bit bigger when time comes for new shoes.
NCPowerStroke
Big question!
There is a 33x10.50R16 interco ss m16 tire, would that fit good on a stock truck? The 295 is a 33.8in tire. The 295 recommends a 7.5in wheel. The 33x10.50 recommends a 7.0in wheel. what size should I get?!? Please help. I want to avoid geting a leveling kit if possible.
TheSmokinStroke2002
Hadley, Michigan
Big question!
You can run a 12.5" wide tire if you want it will just bulge. I know of Alot of people running that set up
Sent from my DROID RAZR using Tapatalk 2
NCPowerStroke
so you guys think it would be ok? i know there is a member on here with an 02 f250 with 295s on stock suspension but i cant remember his user name
PDT1081
Bowling Green, OH
I think CROWZ had started a thread on these on the other site a couple years ago. Might try PM-ing him and see if he will chime in.
