Intercooler Pipes
CoastalF350
Im wanting to dress up the 6.0 under the hood. Any tips on painting the piping? Do i have to use High temp spray paint?
Coxey Diesel
Athens Alabama
Why no get a set of polished pipes from No Limit? Then you'd have no down time and it would look mucho better, IMO
bigrpowr
<How I Fly
Administrator
Steve...did mike change his hot side pipe? I got one through you last year and it didn't fit. I see it looks different than the one I received.
got ur pm was just crazy busy at the time and forgot to respond. No it has not changed, other than urs I have never had a fitment issue. Mind you I've only sold maybe 10 at most. I have no idea what coulda been wrong with yours. I can't remember did we send a replacement ?
strokin6L
Springville NY
Mike...didn't get a replacement pipe. The reason it didn't fit is because the 03-early 04 trucks have the A/C line going over the top of the pipe. So in order to remove/install the pipe...you have to fish it in/out from underneath. The way the bends were or how it was configured...I wasn't able to fish it under the A/C line. Now the later build trucks probably don't have an issue because the A/C line isn't like that. I can't remember if I sent you pics of my stock pipe and your pipe side by side. But there is quite a difference. I'll post up a couple when I get a chance. I really wish it would've fit cause it would've complimented the engine bay off with already having the cold side in there!
