West Point
The Library
6.4 Tech & FAQ
Intermittent Heater Temp control
[QUOTE="makuloco2000, post: 867361, member: 12570"] Heat not working right? You put it on cold and it blows hot or vice versa? Your blend door actuator is likely at fault. So I figured this was common enough on the 2008-10 Superduties to make a video of the temp blend door actuator replacement. It involves pulling some pieces of the dash that many may not be comfortable with, if you follow my video I will walk you through it. Hope this helps! [YOUTUBE]dYPOtin3JUk[/YOUTUBE] [/QUOTE]
10R140 failure
Latest: PSD-BLACK-CLOUD
Friday at 1:04 PM
2017+ 6.7 Aluminum Super Duty
2010 headunit
Latest: glog
Wednesday at 1:17 PM
6.4 Tech
D
Latest: donaldtfreeman
Tuesday at 10:43 AM
6.0 Tech & FAQ
Latest: Tiha
Tuesday at 8:07 AM
7.3 Tech & FAQ
Latest: ju015dd
May 4, 2025
6.0 Aftermarket
Jacobzek
West Point
The Library
6.4 Tech & FAQ
