Cobra 19 & 54
Here I go again. Any ideas, rod knock, cracked injector, ???
:cursing: :cursing: :cursing: :cursing: :wtf:
how bad was it smoking, did it just start doing this, what codes did it throw, sounds like it could be a compression washer fail, or cracked tip but if it was i would think your cylinder would get filled with fuel and she would be locked
Man, that sounds REALLY bad. Is it popping back through your intake? Sure sounds like a hard metalic knock.
not that I could tell. Sounds like it's coming from the bottom of the motor. You can faintly hear the squeal that started when the knocking did. It was immediate. That's what makes me think its the bottom end.
