Installing my boost gauge Can I tee off here? 95 f350 Sent by mental telepathy.
Apr 13, 2014 #1 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. Installing my boost gauge Can I tee off here? 95 f350 Sent by mental telepathy.
Apr 13, 2014 #2 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. Sent by mental telepathy.
Apr 13, 2014 #3 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 8 Location VA Yes. You can also put a boost fooler there too.
Apr 13, 2014 #4 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. Thanks magnum Sent by mental telepathy.
Apr 13, 2014 #5 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 8 Location VA Put the EGT probe at the end of one of the manifolds.
Apr 13, 2014 #6 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. Got both gauges installed exactly per directions and I have nothing no lights no boost I am starting to wonder if the wiring directions are wrong Anyone know if these pictures are correct?? Boost and pyrometer Sent by mental telepathy.
Apr 13, 2014 #7 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. I have ign switch power and parking light power up to the plugs The dimmer switch works with a test light But plug it into the gauge and I have nothing Sent by mental telepathy.
Apr 13, 2014 #8 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. Man Do I feel like an ass..... Bad freakin ground!! Got them working Sent by mental telepathy.
Apr 13, 2014 #9 JohnT24 Active member Joined May 23, 2013 Messages 868 Reaction score 34 Location OXFORD CT. That pic was taken at 3000 rpm The boost gauge reads less than 5 lbs Is that normal For a stock 7.3? Sent by mental telepathy.
Apr 13, 2014 #10 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 8 Location VA Yeah that's normal. Under load will be more.
Apr 13, 2014 #11 Arisley Moderator Joined May 18, 2011 Messages 9,385 Reaction score 30 Location Arlington, Texas None or very little boost neutral. Sent from my SM-T110 using Tapatalk
