ISO: dually pickup axles
powerstrokin97
In search of dually pickup axles, cannot be cab and chassis as they are too narrow. 3.55 or 4.10 gears.
In or around central ky, but will travel if you have them. Cash in hand.
7.3powerstroke00
Brownwood
If you are doing a dually swap and already have a Dana 60 up front all you have to have is the 4wd dually hubs and rotors from an obs for the front. Bearings seals and caliper are the same, they will even swap onto the Dana 50 ttb..... If you already have 4.10 gears finding a rear axle should be fairly easy....
sent from the best place on earth! TEXAS!
