Power Strokes
6.4 Aftermarket
It's running!!!
[QUOTE="Kind, post: 996116, member: 410"] Yeah the trans defiantly needs dialing in. I could probably see more boost if the TC wasn't slipping so much. It would be nice to lock it once the trucks is over 15psi in each gear from 2nd maybe 3rd and above. I also tried a little launch. Left at 4psi, any higher and the tires spun. Even at 4psi there was no bog or lag, it just built boost and speed effortlessly. I'm definitely excited to take it to the track. Another thing I noticed was keeping the tire spin to a minimum on launch was much easier then when i use to run a bunch of nitrous and stick turbos. Sent from my subconscious to your screen. [/QUOTE]
02 F250 7.3 Will crank, WTS stays on, no start, no OBD
Latest: Sterling6.7
Sunday at 8:57 PM
7.3 Tech
P0087
Latest: DEEZUZ
Sunday at 11:49 AM
6.4 Tech & FAQ
2015-2019 6.7 HPFP New In Box
Latest: lincolnlocker
Jun 1, 2026
Engine and Drivetrain
First 6.0L (56k warning)
Latest: adrianspeeder
May 26, 2026
Extra external motor oil cooler?
Latest: justinlogue5_0
May 26, 2026
7.3 Tech
JoeDiesle
Power Strokes
6.4 Aftermarket
It's running!!!
