lil_fenner08
The best transmission on the market! Used on my triple turbo setup that was built this spring. Will come with everything needed to install on a 6.4. Suncoast converter just going back to a 5r so i can have cruise control, i mean after all it is a daily driver lol
6500 OBO
Features of EVERY JOHN WOOD CUSTOM RACE TRANSMISSION:
• Custom Billet Triple Disc Torque Converter with Billet Stator *
• Custom Torque Converter Stall Speeds Available *
• Extensive Cryogenic Treatment including Billet Parts *
• Pump Mating Surfaces CNC Machined for Perfect Seal
• Hardened Gears Installed in Transmission Pump
• Coast Clutch Snap Ring Issue Fixed
• Center Support CNC Machined for Square Fit & Reduced Play
• Coast Clutch Modified for (1) Extra Clutch
• Overdrive Clutch Modified for (1) Extra Clutch
• Forward Drum Modified for (1) Extra Clutch
• Low/Reverse Modified for (1) Extra Clutch
• Direct Drum Modified for (1) Extra Clutch
• Intermediate Drum Modified for (1) Extra Clutch
• Custom Machined Billet Forward Drum
• Custom Machined Billet Input Shaft
• Custom Machined Billet Intermediate Shaft *
• Custom Machined Billet Output Shaft *
• Modified Rear Planetary - Torrington Bearing Repl. Babbit Washer
• Welded/Reinforced Reverse Hub
• Custom Tuned Accumulator Body (valve body)
• Anti-Stick 2-3 Shift Valve in Main Valve Body
• Custom Low/Reverse Boost Spring in Main Valve Body
• Brand New OEM Ford Solenoid
• Custom Machined Chromoly Overdrive Planetary
• Absolutely NO CHEAP OVERSEAS Upgrade Parts!
6500 OBO
