Platinumf250
Have a 13 that I just installed an sctx4 on. Used the canned tunes because I haven't deleted it yet. All stock I put the "street" tune on and went to drive it around. Did a few 25% throttle pulls to about 80mph, then 50%, etc until full throttle. Truck didn't run like I thought it would and sometimes wouldnt build over 10lbs of boost on full throttle. So I chalked it up to the computer still learning the new tune and needing some miles put on it. Put a couple hundred miles on and it started running better. Could build about 20lbs of boost.
Got comfortable with that so I downloaded the "performance" tune. Went through the same process. Turbo would surge between 17-24lbs of boost under 50-75% throttle. Wouldn't build over 10lbs 100% throttle. Pulled over shut the truck off for a min, started it back up, rolled into the throttle until 100% and it seemed normal. About 22-25lbs boost and ran good. Truck just had no get up and go from a dead stop. Runs better now that I put a couple hundred miles on it.
Just installed a 5" no limit intake and the truck is doing the same thing. Can make a couple wot pulls and be fine then it won't build more then 10lbs of boost. Really slow off the line. Chalking it up to the computer re calibrating for the intake.
Not bashing the intake at all I know that has nothing to do with it! Just being paranoid about everything I guess. First diesel.
Tell me what y'all think. Is this normal? Has innovative custom tunes and hope to have it all deleted in the next week or two. Maybe the custom tunes are better. Just seemed like the turbo lit a lot sooner stock. Pulls way harder now when it does light. Just not as instant as it used to be.
