Just wanting front springs
DEEZUZ
NO PUKESTERS
NWI
so in less than a year after I installed new leaf spring bushings, which btw was the biggest pain in the ass, the one side is bad again and starting to slip and BANG. Tired of this... Truck has a 6 inch lift, and I used SUPERLIFT bushings so I assume the liftkit is from Superlift. Does it matter what brand spring I use? these are also rusting and the pins on the ends are sheared, causing even worse sliding on turns...
Any suggestions? truck is 2002
907DAVE
AK
Would it not be cheaper to get some new center bolts and a set of Energy bushings?
DEEZUZ
NO PUKESTERS
NWI
why, so they too can just slide inside the spring like they are currently doing?
GTOKILLER
Charlotte Mi.
I think he is saying use a better bushing in the existing spring, if its that bad I would contact superlift about maybe a warranty set of leafs thats bad!!
