KC stage 2 turbo
KCTurbos
This is a slightly used KC stage 2 turbo. It was used on my personal truck to test out our new drilled holes stage 2 turbos that will be coming out soon. Ran awesome!!! On the truck for around 5000 miles. Nothing wrong with the turbo except a few scratches and a little rust.
Here is the description:
6.0 Powerstroke Stage 2 Turbo (AKA Extreme Street/Tow) – This is a great turbo for those looking to push the limits of their truck and get a lot more out of them over stock. This turbo is made for those who are looking for more top end power but still want to have the ability to tow max weight. This turbo will tow max weight as long as you watch your temps and keep your rpms up. This turbo has a very similar whistle to the powermax/2003 turbos. SPECS: 64x88mm single plane billet wheel with extended tips, .72ar race compressor cover, 72.5x66 10 blade turbine wheel, new high flowing billet vanes, and upgraded 360 thrust bearing. 100% drop in (no modifications required) Recommended for Stock – 190cc injectors (475-575hp)
$1000
Will come with 6 month warranty
KCTurbos
Sorry... only fits 2004-2007... unless you don't mind chopping the 3rd mounting ear off (lots of guys run it that way)
