Leaf springs
SoCalPSD
Riverside Ca
Anyone pull a few springs out of the rear leafs? I already pulled the over load between the axel and leaf and now im considering pulling another one or two out to bring the rear down?
Fat fingered from the phone-Corey
SoCalPSD
Riverside Ca
If I remember correctly dz somthin another member here pulled leafs hopefully he will chime in later.
Rupp250
I pulled leafs out of the rear. I only have two full length leafs and the thick short bottom one. I have onboard air and bags so heavy loads are not a problem. Does ride nicer though. I also have some stuff here to build some traction bars to stop any axle wrap.
I also cut down leafs and added two per side to raise the front a little. A mini mini spring pack you can say.
