Lets talk dilution
BlueWaffle
Grapevine, TX
ok...i'm having a hell of a time getting an accurate oil level reading on my dipstick. i'm trying to keep an eye on it for dilution but i just can't seem to read a consistent level. i'll run it up to op temp then let it sit for about 20 min and check it. usually the entire indicator is coated with oil. i'll drain some out, check again and still the whole thing is full.
anyways...what i want to know is, how much oil dilution is "acceptable"? i know some hybrids will do it as will some larger conventionals but i just want to know that if I do have it, when do i need to consider pulling injectors out? i just putt around town mostly, usually run errands in it and drive it on the weekends. change oil every 3k. i mean, if it's diluting at all, do i need to stop driving it or is some to be expected? also, can anyone quantify what "some" would be?
begin...
jbkingranch
Middle of nowhere North Dakota
Pull a oil sample so you know for sure what's in the oil and how it's holding up. I've had up to 3.6% dilution on my Amsoil 5W-40 and didn't loose much viscosity. Best way to start is send a sample of unused oil in and most test the viscosity at 100 degrees Celsius. Then run your oil for whatever interval you want. Send another sample in to see if any fuel is in it or if there is see what happened to your viscosity with the oil dilution.
2wd-fire
yeah i would just send some out at say 2500 miles and see where you stand.
Pizza pig
MD
I cant ever get the same reading on my dipstick... Youre not alone
strokin6L
Springville NY
I know your hybrids aren't as big as most guys lance, but i remember when Shawn was running Hypermax hybrids in his race truck....i think he said he had to change the oil after about 12 passes down the track(so about 3 miles). But i know hybrids have gotten better with less oil dilution.
Cutting-Edge Diesel
Newkirk, OK
My hypermax hybrids were about 3 passes lol But the barrel and plunger specs were pretty loose compared to my RCD hybrids
BlueWaffle
Grapevine, TX
i just want to know what is an "acceptable" amount of dilution to have between oil changes...
i think i finally got my oil level stabilized so hopefully i'll be able to tell after a couple weeks of driving
Redneck6.0L
No dilution is good. My ii hybrids knock on wood haven't had a issue yet, other hybrids I've tryed always had that issue. If your draining oil to bring the level back to normal. That's to much, not good
BlueWaffle
Grapevine, TX
i think I overfilled it last oil change. I've never paid attention to my oil level until I put these hybrids in. I'm going to check the oil level tomorrow morning before I run it and actually get an accurate benchmark then drive it a few days and check it again.
Pizza pig
MD
Just drive it until it smokes and knocks... You know the scientific/lazy way!
Helen Keller sent this?
