Leveling Kit Block and shackle question
JoshFulk
Springfield, IL
I am about to put a 2" leveling kit Block and shackle from Supreme Suspension. My question is if I get a shock that says front lift w/0.05"-3" lift should I still install the shackle or is the shackle not needed. In my mind if I install the shackle. I will keep the shock stroke length to its max but at the same time I it would compress the shock on the install more with the shackle shortening the distance of install. Let me know your opinion and what you think I am by no means a mechanic but I am a weekend project type of guy that can figure it out. I am looking at the Skyjacker shocks if that helps anything
2005 F250 6.0 STOCK
David N
Eastern NC
Are you talking about the rear shackle?
Because there shouldn't be a front shackle? Its only a coil spring.
JoshFulk
Springfield, IL
This set up goes block under the coil then there's a shackle for front shocks. The shock and coil are seperate on my F250.
INFRNL
Colorado
Maybe its some kind of shock extender/bracket, idk
Maybe that is if you keep you current shock. If you get a shock for a leveling kit, just use the new shock
JoshFulk
Springfield, IL
Ok so since I am changing out the shocks and getting a longer shock with more stroke then I currently have that covers a 2in lift/leveling I should be good to just leave that shackle off and just install my block. Thanks for the help.
