Leveling Kit options?
GReeves
Texas
Hey guys, getting ready to finally throw wheels and tires on my truck! I'm pretty much a lurker on this site and I've seen several different answers to my question so here goes...
I am ordering 22x10 Fuel Mavericks -24 offset with 35x12.50x22 Toyo OpenCountry AT2's and I have a Ready Lift 1.5" and 2.5" leveling kit sitting at the house. Can I get away with using the 1.5" blocks with trimming or should I go with the 2.5" leveling blocks? If I go with the 2.5", will I need to run a track bar drop down bracket/adjustable track bar or any other suspension mods??? Don't really have the money to spend on a BDS or Carli suspension like I really want so having to do what I can to fit this wheel/tire combo...I know it sucks but these leveling blocks are so simple and easy...
Going on a 2015 CCSB FX4 F250
UNBROKEN
I guess it's my grouchy old age showing but does anyone even attempt to look around before they post a new question? This combo has to be the single most discussed set-up out there with no less than 4 current threads covering it.
JRLott
TX
If I put 2.5" Carli springs, ReadyLift track bar bracket, ReadyLift radius arm drop brackets, 4" blocks in the rear, Bilstein shocks, and an SCT EGT probe, can I run 275/65R20 tires on the factory rims? I have a Fumoto valve, but it's been a while since I stayed in a Holiday Inn.
UNBROKEN
Only if you add a Chunchit valve and carefully dial in your rev gain.
JRLott
TX
D@mn it! I hadn't thought of that. I've been told the Marzle Vanes wouldn't cause an issue...any experience?
GReeves
Texas
Yes, Unbroken, I do read every thread before posting a question, and if you would read my post, I referenced that there were multiple answers to my question, so I am here asking for the best answer you guys with knowledge could give me....
so what makes the answers you would get in this thread any different than the multiple answers in other threads?
