Lift ordered now onto Tires and Rims Question
bricewise
Finally decided to pull the trigger on an Icon stage 4 4.5" lift and PMF traction bars. So now I'm trying to figure out what is the widest sized tire I can fit on the 2012 KR 20" rim. Also has is that determined? Any suggested references or places to look would be helpful
If I can't get it as wide as I want it, anybody know some good deals for a set of 20" Novakanes.
WHY NOT
Carlyle IL
12.50 is the max for the stock wheels. If you want more than that you will need to go aftermarket which I would suggest anyways
MINK
London,OH
Even the 12.50 will likely rub with the lack of offset the stock wheels have.
