Light Bar Install
imelmo
I got my 50" light bar in from No Limit. :D I'm mounting it near the front of the roof of the truck. Where are y'all running the wire into the truck from there?
Powerstroked162
On Da Juice
Wa. State
Do you have a mount yet? If not, you could look into getting something from Matt at cutting edge. His light bar mount came out perfect on the roof. Very clean and subtle
smokinstroker
Texas
Danny, you can drop the wire right inside the door jam, there is more than enough room with no pinching.
Assuming your going to run a SoCal or vision x mount?
If so the wire will be right near the corner of the cab/ door jam.
