Limited Lifetime 7.3 Injector Warranty
Bremen, Ohio
We are proud to announce that as of 01/01/2012 we are offering a Limited Lifetime warranty on all of our remanufactured 7.3 Fuel Injectors. We will be sending warranty cards out with our injectors that need to be filled out and returned, but after that you are set!
Here are the details... Enjoy! :thumbsup:
INTRODUCING THE BEST WARRANTY COVERAGE IN THE INDUSTRY!!!
Limited Lifetime 7.3L Power Stroke Fuel Injector Warranty
Limited Lifetime Warranty card must be filled out entirely and returned within thirty (30) days with injector cores and proof of purchase to qualify. This warranty is only in effect for the original purchaser and original vehicle listed on registration. No transfers of ownership or vehicles allowed!
Unlimited Diesel Performance Limited Lifetime Warranty covers all faulty 7.3L Power Stroke Fuel Injector(s) caused by defects in material and/or workmanship from internally lubricated moving parts, as well as Internal/external o-rings, and properly seated nozzle gaskets. This warranty also covers all modifications made to the 7.3L Power Stroke Fuel Injector by Unlimited Diesel Performance
7.3L Power Stroke Fuel Injectors must have been purchased directly through Unlimited Diesel Performance or one of our Authorized Dealers/Installers.
The original sales receipt is required to be accompanied by this Warranty Card for all warranties to be activated and honored. 7.3L Power Stroke Fuel Injectors must be purchased at our minimum advertised price or above to be eligible.
Unlimited Diesel Performance warrants only the 7.3L Power Stroke Fuel Injector and will not pay any lost wages, shipping costs, hotel accommodations, towing, food, fines or taxes.
Unlimited Diesel Performance will ONLY cover labor performed at Unlimited Diesel Performance or one of our Authorized Dealers/Installers to replace a faulty 7.3L Power Stroke Fuel Injector(s) after the 7.3L Power Stroke Fuel Injector is flow tested and deemed faulty. Labor will only be reimbursed to the Authorized Dealer/installer, NOT THE CONSUMER. Labor will not be covered or reimbursed under any circumstance if performed by the consumer or any unauthorized installer.
Unlimited Diesel Performance reserves the right to repair the 7.3L Power Stroke Fuel Injector rather than replace it if a warranty claim is accepted.
Unlimited Diesel Performance Limited Lifetime warranty does not cover abuse, misuse, or improper installation, fuel contamination (water in fuel, fuel pump failure debris, bio diesel), poor filtration, foreign objects entering fuel, improper maintenance intervals (oil changed irregularly causing stiction/poppet valve damage), fuel pump failure (low fuel pressure).
Unlimited Diesel Performance Limited Lifetime warranty does not cover Fuel Injector damage as a result of engine failure.
Unlimited Diesel Performance requires an oil change be performed, and a new fuel filter installed with all injector installations.
Unlimited Diesel Performance may require all maintenance records of vehicle after installation date, a picture of VIN number and current mileage before warranty work is approved
Unlimited Diesel Performance will only cover UPS Ground shipping for a replacement 7.3L Power Stroke Fuel Injector to the consumer, and return shipping back to Unlimited Diesel Performance. Expedited shipping will not be covered by our warranty. The consumer agrees to pay the replacement cost of the 7.3L Power Stroke Fuel Injector until it is determined to be a warrantable injector. Consumer will be refunded within 14 days of inspection if warranty applies.
If Warranty Card is received after THIRTY (30) Days, original eighteen (18) month warranty will take effect. If Warranty Card is not received after SIXTY (60) Days, No Warranty will be provided.
NO EXCEPTIONS!
