Long and short injector bolts
NC714
Walkertown, NC
:whs:
Install/torque the top hold down bolt with shoulder, then put the injector in and then install/torque the lower hold down bolt
markfuga
Leesburg, VA
:whs: Too.
Torque is 10 ft/lbs (120 inch pounds)! There is some bad data on the internet (dramatic gasp) stating the spec to be 25 to 30 ft/lbs. You'll snap the bolts if you torque them that tight.
old man dave
Petaluma, CA
The 120 in/lbs is the revised factory torque figure. Originally, the old factory service manuals said 105 in/lbs. So, if you use an old factory manual it will have the wrong value.
